team associated sort son SC10 en 4x4 avec transmission pas courroie ... en kit 1/10 donc
http://teamassociated.com/cars_and_trucks/SC10_4x4/Kit/
http://www.youtube.com/v/eDvibq1jsP4
SC10 4x4 Kit
1:10 Scale 4WD Electric Short Course Truck Kit. Experience the thrill of four-wheel-drive action and performance with the SC10 4x4!
Features
* Unique dual gearbox drive train coupled together with a 5mm heavy duty belt system with external tension adjustment
* 32 pitch front and rear gearboxes with sealed fluid filled differentials
* Decoupled center slipper clutch allows for front and rear wheel drive to slip independently, resulting in more traction and stability on bumpy track conditions
* CVAs with captured drive pins and heavy duty 6mm alloy axles
* 12mm hex drive KMC® replica wheels front and rear with aggressive short course racing tires
* Championship short course racing body (clear), with Team Associated decal sheet
* 13mm blue aluminum big-bore threaded shocks with low friction X-ring seals
* Composite modular tub chassis with Low-CG and Low Polar Moment design
* Enclosed water-resistant receiver box, and removable ESC tray for easy clean up and maintenance
* Ball bearing steering system with adjustable steering stops
* All metric hardware and ball bearings throughout
* Uses most 540 and 550 brushless motors
hier il était a 269.99 $ aujourd'hui 365.99 $ !! http://www3.towerhobbies.com/cgi-bin/wt ... LXAXLK&P=7 ??
