voila la ch'tite new's de chez traxxas ! encore un kit B.A.R qui sort ! (bar anti roulie)
la B.A.R tant attendu par certain !
voila les photos
Official Press Release:
The Traxxas® Revo® sway bar kit is a must have for Revo racers
everywhere. The kit was created, developed, and extensively field
tested by Traxxas driver and reigning national champion Tim Roberts.
The unique patent-pending design was built around the original
engineering software models to compliment the advanced Revo progressive
suspension geometry. The exact placement and perfect fitment allow
maximum adjustability and tuning, while eliminating the chance of
interference or clearance problems. The lateral sway bar resistance
works with the suspension components to maximize traction and handling.
The sway bar kit fits Revo and Revo 3.3, and it includes front and rear
linkages, mounts, thick and thin sway bars, hardware, comprehensive
installation instructions, and tuning guide.
Features:
-Fully adjustable design
-Heavy-duty components
-Improves track handling and corner speed
-Compatible with stock rear exhaust
-Front/rear thick and thin sway bars are included
-Pre-assembled front and rear linkages
-Includes installation instructions and tuning guide
-Complete and easy to install
-Perfect Traxxas fit
5498 - Sway Bar Kit for Revo & Revo 3.3 - $30.00
Replacement Parts:
5495 - Sway Bar Linkage, Front (Revo) (3x70mm turnbuckle) (2) (assembled with rod ends, hollow balls and ball studs) - $12.00
5496 - Sway Bar mounts (front & rear) (Revo)/ swaybar wires (front & rear) (4)/ drill guide/ spacers - $10.00
5497 - Sway Bar Linkage, Rear (Revo) (3x30mm turnbuckle) (2)/ (assembled with rod ends, hollow balls and ball studs) - $12.00
petit debat entre toutes les B.A.R sur le marché !
new era :
traxxas :
tekno RC :
aricospeedrevo
(texte by Chezoit, grand merci a toi
