Echelle 1/10
4WD
moteur Team Associated 18 Pro
Ca va être une petite bombe ce mini MGT, si il a en plus la fiabilité de son grand frère....
La suite
http://www.rccaraction.com//Media//Core ... .ps[1].jpg
The Mini MGT 3.0 is a chip off the old block
Inspired by the overwhelming popularity and success of Team Associated’s original MGT, the Mini MGT 3.0 packs all the same dirt-kicking performance into a compact 1:10 scale package. The Mini MGT 3.0 brings with it all of the features: a 2-speed automatic transmission with reverse, eight coil-over oil-filled shocks, full precision ball bearings, and specially designed Team Associated all-terrain tires, just to name a few! The Mini MGT comes factory assembled with a painted body, ready for you to fire up and rip up the road!
• All steel differential internal components for ultimate durability
• Dual drilled brake rotors fitted with a unique alignment device that keeps the brakes friction free until engaged
• Specially designed tire to combine excellent performance in all conditions
• Heavy duty metal-gear hi-torque servo
• 2-speed automatic transmission with reverse has an optimized gear ratio for awesome acceleration
• Ultra rigid extruded aluminum chassis optimized for the rigors of off-road use
• 14.0mm steel drive hexes
• Elliptical “buffer” style bumpers that easily withstand heavy impacts
• Trophy truck inspired styling
• Team Associated 18 Pro two-stroke nitro engine with pull-start
• Eight oil-filled independent coil-over shock absorbers
• Sealed radio box
• 28 precision ball bearings
• 110cc fuel tank for long run time
• Team Associated XP3 radio system, glow igniter and fuel bottle included!
Source : Radio Control Zone
