au menu :
Features:
> Factory built with 3 channel / 10 model memory FM radio system.
> Dual high torque, metal-geared steering servos.
> Heavy duty 5mm bracing front and rear.
> XTM's powerful .28 rear exhaust engine.
> Polished aluminum rear exhaust tuned pipe system.
> 8 threaded and polished aluminum oil-filled shocks.
> Steel 2-speed with 75/70 size gearing for low end power.
> Drive train uses rubber sealed bearings.
> Large 11.4cm(4.5”) wheels with 17mm hex hubs.
> Massive 17.8cm(7”) tires with foam inserts.
> Steel alloy, socket head screws.
> Huge 290cc fuel tank for long run times
> Dust resistant receiver and battery boxes.
> 4 steel vented brake discs.
> Bevel geared differentials front and rear.
> Front universal joints.
> Large front and rear chrome bumpers.
Specifications:
> Length - 63.5cm(25”)
> Height - 30.5cm(12”)
> Width - 43.2cm(17”)
> Weight - 6.35kg(14lbs.)
> Wheelbase - 41.91cm(16.5”)
> Tire diameter - 17.78cm(7”)
> Ground clearance - 10.16cm(4”) with suspension extended
prix moins de 400$
source radiocontrolzone
