j'ai entendu dire que certains vario ne sont pas capables d'encaisser le bec 6 v avec deux servos
lequel me conseillez-vous ???
FEATURES: Works with all motors down to 10 turns
Fully proportional Forward, Brake, and Reverse
QuickTune one button setup
Adjustable Reverse delay from 0-4 seconds plus Reverse disable
High frequency regenerating operation extends runtime and increases
motor life
Factory installed motor and battery terminals
High efficiency heatsink for cool operation
Thermal sensor for optimum performance
INCLUDES: (1) Tekin Rebel 2 ESC
(3) Zip Ties
(3) Squares of double sided tape
(3) 0.1 uF Motor Capacitors
(3) Receiver Connectors, KO, JR (FUT is installed)
REQUIRES: Installation
SPECS: Controls: Forward/Brake/Reverse
Input Voltage: 4-10 Cells (Stock Motor) 4-8 Cells (Mod Motor)
On resistance: 0.0038
Frequency: 2000Hz
Power Wires: (4) 15 Gauge Silicone
Plugs: Tamiya/Bullet
BEC: 6.0V / 5.0A
Weight (with wires): 2.4oz (68g)
Size: 1.8" x 1.4" x 1.0" (46mm x 35mm x 25mm)
Motor Limit: 10 Turn (6 cells)
