le pro kit à +/-400$ : At the center of the Matrix TR Pro kit is the 3mm Hard anodized grey chassis along with the trick arched composite chassis braces. At the front and rear of the truck, beefy 4mm 7075 shock towers handle the suspension duties along with the Big Bore 16.5mm shocks. With 23mm on all corners of the truck, you won’t be short of wheel choices
le Factory Race Edition à +/-500$ : The Factory Race Matrix TR lightened blue anodized 23mm wheel hexes, 5mm red anodized 7075 T-6 CNC shock towers to stand up to the abuse of the supercross style jumps at the tracks, Red anodized 7075 Inner Suspension Plates, as well as a carbon center diff plate for that trick factory look. Just add your favorite truggy engine, pipe, and radio gear, you’ll be ready to start winning championships like CEN Factory drivers Andy Smolnik, Jason Ashton, and Gene Hickerson.
http://www.cenracing.com/area51/matrixarenafre.html
