A
Amortisseur = shock
angle de braquage = Steering Radius
accus = battery
aileron = wing
B
Bougie = Glow plug
boite de vitesses = gear shift ou gear box
C
cloche embrayage= clutch bell
couronne =spur gear
chape direction = turnbuckle
culasse = cooling head
charbon = power brush ou motor brushes
Carburateur= carburator ou carbs
Chemise = cylinder
Bielle = connecting rod
Carter = casing
Carrosserie = body (peinte/painted), (perso/custom)
Differentiel = differential ou diff
D
Durite = Fuel Pipe
Disque de frein = brake disc
Direction=steering
E
Ecrou = NUT
embrayage = clutch
F
Filtre a air= air filter
frein=brake
filtre à essence = fuel filter
G
Gras (reglage) = Richer
H
Heagone de roue= drive washer
I
J
joint siliconne = manifold silicone
K
L
M
moteur electrique = motor
moteur thermique = engine
N
moteur noyé = flooding
O
Option = part
P
Pneu = tire
palonier = servo arm
Platine radio carbone = carbon fiber radio tray
Q
R
Resonnateur= Exhaust ou pipe ou muffler ou tuned pipe
Roulement = Bearing ou ball bearing
Reservoir = fuel tank
Roue = wheel
Ressort = Spring
roue libre = fly whell ou ONE WAY
resistance = capacitor
recepteur = receiver
renforts chassis verticaux sur les TT et truggy = chassis Brace
Renfort chassis avant horizontal = front to plate
Renfort diff central = center brace
S
support moteur = engin mount
sauve servo = servo saver
Sec (reglage) = leaner
Soquet de demarrage = Glow Plug Starter
Supports d'amortos arriere et avant = rear and front shock tower
T
tirette = pull start
Travail Fait main (perso quoi ...) = handmade work
train av/ar = front/rear drive train
U
V
vilebrequin = crankshaft
Visse = screw
variateur = electric speed control ou ESC
W
X
Y
Z
merci pour le POST-IT = Thank for the POST-IT =)
monpremier post-it
