La toute dernière de chez Spektrum, la DX3S
Spektrum RC a écrit :
DX3S 3 Channel DSM Surface Radio with Telemetry
Combining Spektrum’s industry-leading 2.4GHz DSM® technology with valuable telemetry features, the DX3S represents the most advanced sport-level DSM radio ever developed. RTR drivers and sport racers can add the safety of telemetry and monitor vital vehicle stats right from their transmitter, without any additional equipment. Keep your engine operating in the optimum temperature range, keep an eye on your battery voltage and check out just how fast your vehicle is running, all right from the large LCD readout of the DX3S.
* The typical telemetry range is 100–200 feet and will vary depending on the operating environment.
Key Features
* Integrated telemetry with graphically depicted gauges on transmitter*
* Monitor your engine or motor’s operating temperature in either Fahrenheit or Celsius
* Never let a low battery stop you in your tracks – the DX3S and integrated telemetry lets you watch over your receiver pack’s voltage to keep you in the running
* Keep tabs on your engine’s operating range-safe high-rev operation
* Includes SR3300T 3-channel receiver with built-in telemetry
* Includes free bonus SR300 3-channel DSM sport receiver
* Rolling selector user interface for fast, easy programming and setup
* 10-model memory
* 10-character model naming
* 3 grip sizes (small, medium, large)
* ModelMatch
* Expert and standard modes
* Digital trims
* Throttle Punch
* Steering dual rate
* Travel adjust
* Servo reverse
* Sub trims
* Exponential
* 3-timer functions
* Aux channel mixing
* Telemetry alerts
* Buzzer adjustments - high, low & off
* Screen contrast
* Transmitter battery alert
* Right hand configuration (only)
Product Specifications
# of Channels: 3
Modulation: DSM
Band: 2.4GHz
Servos: None
Receiver: SR3300T and SR300
Model Memory: 10
Transmitter (Tx) Battery Type: 4 AA Alkaline (included)
Tech Notes
Receiver Compatibility
The DX3S is a DSM transmitter and works will all Spektrum DSM surface receivers including the SR3000, SR3001, SR3500, SR300, and SR3300T. The DX3S is not compatible with the SR3100 DSM2 receiver.
Telemetry Range
http://www.spektrumrc.com/Products/Defa ... Id=SPM3130
Pour ce qui est du prix, elle est moins cher que la DX3R, car déjà elle est en DSM et pas en DSM2 comme la R, donc elle est comme les DX2.0/3.0
http://www.amainhobbies.com/product_inf ... s_id/29216
C'est vraiment pas cher pour une radio 2.4ghz, avec 2 récepteurs dont un qui inclus la télémétrie, tous les capteurs, etc...
Fab
