vu sur radio controlzone
CRAWLER BRUSHLESS MOTOR FEATURES
Specifically designed for R/C vehicles that require precise movement control
Sensor-based technology for excellent low-speed drivability
High-strength Sintered rotor for unmatched performance
Oversized Front Bearing for extra durability and extended life
Aluminum ribbed end bells for additional cooling
Direct-Solder Wiring Tabs for flexible soldering options
Ideal for vehicles that have separate transmissions like the Tamiya® Clod Buster™
Minimal Maintenance
Thermal Overload Protection
Low cogging
Designed and assembled by Novak in the USA using globally-sourced components
CRAWLER BRUSHLESS MOTOR SPECIFICATIONS
Number of Turns: 18.5
Design: Sensor-based
Input Voltage: 4-7 cells (1.2V/cell) or 2S Li-Po cells
Size: 2.08”L x 1.41”D (52.8 x 35.8mm)
Shaft Diameter: 0.125” (3.2 mm) [accepts all existing pinion gears]
Bearing: Oversized (1/2” x 3/16”) Front; Standard Rear (3/8” x 1/8”
Weight: 6.73 oz. (191 grams)
Magnet: One-piece, multi-pole cylindrical high-strength Sintered neodymium
CRAWLER BRUSHLESS ESC FEATURES
Two user-selectable brushless throttle profiles that feature Zero Reverse Delay and adjustable high-powered Drag Brakes (or “hill” or “hold” brakes)
Profiles include 1 with standard motor rotation, and 1 with reverse motor rotation
Built-in Li-Poly Cutoff Protection (can be activated in either throttle profile)
User-friendly programming interface with 4 status LEDs
Novak’s One-Touch Set-Up™ (still the easiest)
Novak’s Radio-Priority Circuitry™
Gold-Plated PCB Direct-Solder Wiring Tabs
User-replaceable input harness
Water-resistant case
Built-in power output for optional 6 volt accessory fan (Novak #5648)
Factory-installed power capacitor
Designed and assembled by Novak in the USA using globally sourced components
CRAWLER BRUSHLESS ESC SPECIFICATIONS
Forward/Reverse Forward, Drag Brake, Reverse
Input Voltage 4-7 Ni-Cd/Ni-MH cells (1.2V/cell) or 2S Li-Po cells
On-Resistance 0.0012 ohms*
Footprint 1.54” x 1.18” (39 x 30 mm)
Weight 2.84 oz. (80.7 g) w/wires; 1.49 oz. (42.2 g) w/o wires
Rated & Braking Current 120 amps per phase*
Power Wires 14-Gauge
BEC 6.0 volt/5.0 amp
Motor Limit 18.5-turn brushless
Discrete Steps 512 Forward; 512 Reverse
Battery Plug Tamiya
Motor Plug None
Voltage Cut-off 6.25 volts (when Li-Poly Cutoff Circuitry is enabled)
http://forums.radiocontrolzone.com/show ... p?t=239085
nouveau BL Novak spécial crawler
