Alors, j'ai trouvé une info qui devrais etre plutot pas mal ...
GST 7.7 specs (GST--> Genesis Super Truck)
- Fully READY TO ROCK (RTR)
- Dual Vertical Chassis design (DVC)
- Shaft Driven 4 wheel Drive
- All new 23mm hex Rims
- New Tire Tread Design
- Unmatched Durability
- Stiff hard coated "white" spring
- Full Precision Ball Bearings
- Carry handle with blue rubber Grips
- Hardened Steel 8mm (5/16inch) thick CVS (Constant Velocity Shafts)
- High Impact skid plate bumpers (Front and Rear)
- Machined 1 piece motor mount with built in cooling fins
- Heavy Duty Spindle and caster blocks with Alloy wheel hexes
- Trimmed, Painted and Decorated Body
- Ruby Green aluminum counter sunk chassis plates
- 5 inch Suspension Travel
- 4 Disk "metal to metal" Brake system
- Fully equipped with Allen Hex Screws
- Front, Center, and Rear differential
- Optional Center Locking unit
- 3-Speed Automatic Forward/Reverse Transmission with adjustableshifting
- Alloy Hinge Pin Supports
- Protected Radio Box and Battery case
- 3 speed transmission
- All Aluminum Differential cases
- Front and Rear Transmission Cases
- Complete Skyion Electronic System
Alors, en gros ... because my english is not a best english ...
C'est un Genesis qui ressemble beaucoup a un Nemesis sachant qu'il a les diff alu,
les amortots du dessus supprimés, frein acier comme le Nemesis, pas de marche arriere ...
Par contre, d'origine en trois vitesse, sublime peinture sur la carro d'origine Genesis,
chassis vert du plus bel effet et je sais pas si j'ai bien compris,
mais il a des roues de Genesis avec exa de 23 ...
Voila voila ...
